20 Most Recent BRAKE BUDDY 39504 - Vantage Select Brake 39504 Questions & Answers
4answers
What is the necessary water-skiing equipment?
The necessary equipment for water-skiing is: Life-jacket, powerboat that can go at least 20 miles per hour, ski-rope, and one or two skis.
1/30/2024 8:48:35 AM • Water Sport • Answered on Jan 30, 2024
4answers
Where can I buy water-skiing equipment?
You can buy water-skiing equipment at local stores or on the internet.
3/28/2022 2:35:58 PM • Water Sport • Answered on Mar 28, 2022
Where can I buy wetsuits?
Wetsuits areavailable at the stores of the main manufacturers (ie. O\'Neil, Quicksilver,Billabong) and at different local shops. In addition, there is a greatselection of wetsuits in which you can buy online. Popular websites include: http://www.dickssportinggoods.com/info/index.jsp?categoryId=222802
9/10/2021 12:19:17 PM • Water Sport • Answered on Sep 10, 2021
Need manual guide for DBX illusion 2 person towable water tube
https://www.wholesalemarine.com/resources/two-person-towable-tubes-buying-guide/
7/31/2021 7:36:07 PM • Water Sport • Answered on Jul 31, 2021
What are the benefits of a wakeboard tower?
A wakeboard tower allows your boat to have more hang time, it can be used for extra space to put wakeboard equipment (ie. racks, speakers), and it can be served for support when walking around the boat.
10/18/2018 7:20:11 AM • Water Sport • Answered on Oct 18, 2018
2answers
Do you need to have waves to paddle board?
No actually it is better to paddle board on less choppy water and flat water is preferred when beginning to practice your skills.
10/1/2018 11:50:16 PM • Water Sport • Answered on Oct 01, 2018
I’m trying to buy a new bathing suit. According to the size chart my bust and hips are one size and my waist is another. Do I go with the bust and hip size? Thank you
Lots of ladies share your problem which is not easily overcome, especially if your waist is larger rather than smaller... You really need to try on several costumes to find the best fit and in the lower price ranges you are likely to discover considerable variation between garments of the same theoretical size. This is because the fabric tends to be cut to a tolerance rather than an exact size. If your waist is smaller I suggest you choose a garment that provides the best fit for your hips and bust but if your waist is larger, practically speaking, you will have little choice and will need to buy to suit your waist and either compromise on the bust/hip fit or have a seamstress make a few slight alterations. Good luck!
4/6/2018 3:11:15 AM • Water Sport • Answered on Apr 06, 2018
2answers
Do I need to wax the top of the paddleboard?
Most paddle boards are made with traction pads attached to the top of the board, these should never be waxed. Boards that do not have the traction pads should be lightly covered with a base wax.
2/5/2018 3:30:29 PM • Water Sport • Answered on Feb 05, 2018
Are body boarding and boogie boarding the same thing?
Yes, they are exactly the same thing. Body boarding has been sometimes called boogie boarding since the invention of the boogie board by an entrepreneur named Tom Morey.
9/17/2017 4:23:51 AM • Water Sport • Answered on Sep 17, 2017
99 yamaha xl 1200 limited rev problem no speed
if the wear ring is installed wrong or the impeller is full of debris this will be the result. look close at the wear ring for scrape marks from the propeller OR are you missing carpet off the rungs of the trailer ?
7/14/2017 1:53:23 AM • Water Sport • Answered on Jul 14, 2017
2answers
What are the best goggles?
Speedo are the best. You can see the rank here: http://blog.djsports.com/2009/10/10/top-10-swimming-goggles/
7/12/2017 10:27:22 AM • Water Sport • Answered on Jul 12, 2017
Yamaha waverunner 1200RECENtly purchased wave runner took out for 4 mile trip ran great took in for evening done inspection and realized it didnt have oil pump only a plate were it should be. so i put
The first thing to check would be the compression. As long as both cylinders are with in 10 psi of each other you should be okay. Both cylinders need to be at least 100 psi. That would be the minimum for a motor to start and run. It should read aprox- 150 -- 165 psi. Also i would check for a possible exhaust leak, that would cause the motor to bog down because the carb is breathing in the exhaust fumes. Try running the motor with the hood up to see if you have a leak.
4/25/2017 1:25:56 PM • Water Sport • Answered on Apr 25, 2017
Yamaha waverunner won't idle and losing power
L stands for limp mode it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil ) have the fault codes read then reset with the scan tool
3/31/2017 6:33:28 AM • Water Sport • Answered on Mar 31, 2017
Vw battery light on
Alt. Is bad pull battery's terminal off while car is running if it dies the alt.needs replaced
1/11/2016 7:16:25 PM • Water Sport • Answered on Jan 11, 2016
2answers
What type of bathing suit should I buy for intensive swimming?
Get a full body one, maybe you should try a famous brand like speedo that will last for a long period of time
9/29/2015 11:23:46 AM • Water Sport • Answered on Sep 29, 2015
2answers
Where can I find online a bright orange 1 piece bathing suit?
4089aa5a-11cc-471f-98e9-801e19f1f15a.jpgCheck BluSilkstockings orange cut-out bathing suit @ www.etsy.com/shopblusilkstockings
9/7/2015 10:41:26 AM • Water Sport • Answered on Sep 07, 2015
0answers
No roostertail
Be the first to answer 6/29/2015 6:02:29 PM • Water Sport • Posted on Jun 29, 2015Be the first to answer
0answers
BRAKE BUDDY 39504 - Vantage Select Brake 39504 Logo
0 questions posted
Top BRAKE BUDDY Water Sport Experts
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a BRAKE BUDDY Water Sport Expert? Answer questions, earn points and help others
View Most Popular
  • BRAKE BUDDY Water Sport
Most Popular Question
no fuel carbs waverunner yamaha xl760
  • Water Sport
