20 Most Recent Apex Digital LD4088 LCD TV Questions & Answers
3answers
I dont have a remote for my APEX tv. I have been trying to change the input from AV to TV but as I scroll through inputs I can't get it to stay on the input I want. Help?
I know this is old but I figured I can post an answer for anyone else looking for a solution. I don't have a remote for my Apex tv and wanted to switch it from TV input to Hdmi 1 to use it as a monitor. You have to press INPUT button to get the menu up. Then press CHANNEL+ or CHANNEL- to change to the input that you want. Then press and HOLD the VOLUME+ button to enter it. That worked for my Apex TV.
12/14/2023 2:07:27 AM • Apex Digital... • Answered on Dec 14, 2023
2answers
I turn the volume all the way down to 1 and it is
go to:
menu>audio>SRS TruSurround XT>off
and it will fix the volume
10/17/2020 2:20:10 PM • Apex Digital... • Answered on Oct 17, 2020
5answers
I got a new Apex LD 4088 LCD TV and the remote is
When I bought this at Target on black Friday, I did not realize the remote was missing. I had a spare universal laying around. Went online for codes and found nothing but codes that didn't work. Bought a low-end one at Target (who refused to give me one after the TV's sold out, said all I could get was a refund but I got a GREAT price on it and didn't want to spend another 150 to replace it.) Low-end remote did not work, returned it and bought a 70 dollar remote and that didn't work either. Got fed up and called Apex, who jerked me around twice before finally telling me there is a special number if you buy it at Target. Called them and they said fax the receipt and serial number and they would mail me a new one. Did this TWICE and never got a remote, called and demanded a supervisor and explained the situation, he ask my name and info and within 5 minutes I had a conformation email with a tracking number. The aim sucks, but it's not the TV, it's the signal on the remote being weak. The supervisor told me there is only 1 universal remote they know of that works with the TV since it is so new. His name is Marcus Chan and his email is [email protected]
Hope this helps!!!
3/4/2019 1:28:38 AM • Apex Digital... • Answered on Mar 04, 2019
TUNER ACTIVATION CODE LD3288M,SERIE:11196212194
I have a problem whith TV, LCD :APEX , model:LD3288M serie:11361580239 ,, i need the tuner activation (ATSC), code for the channel,, please help me, my e-mail : [email protected]
4/5/2018 11:51:52 PM • Apex Digital... • Answered on Apr 05, 2018
Have an Apex digital TV
Press the volume button up or down after you have made your input select
12/28/2016 7:19:01 PM • Apex Digital... • Answered on Dec 28, 2016
2answers
Big shadow on tv model ld4088
You can download the manual from here.
6/6/2016 11:04:54 PM • Apex Digital... • Answered on Jun 06, 2016
2answers
No picture or sound just blue pwr light on apex 40 inch LCD what's going on?
first place to begin is if able test voltages in and out of the power board inside the set---if not able to do that consider having a shop look at it.If you get it open:8_27_2012_9_12_28_pm.jpg8_27_2012_9_13_04_pm.jpg
6/6/2016 10:45:09 PM • Apex Digital... • Answered on Jun 06, 2016
2answers
Apex LD4088 LCD Power but no picture
If you have replaced the inverter board and the power board with known good parts the the panel itself is bad.
6/6/2016 1:43:48 AM • Apex Digital... • Answered on Jun 06, 2016
2answers
Apex LD4088 no picture
The inverter is the usual suspect with that symptom. It may be hard to find a replacement inverter for an apex model. But you might be able to get one from www.tvrepairworld.com
6/6/2016 1:38:40 AM • Apex Digital... • Answered on Jun 06, 2016
2answers
It will not come on
If the light comes on but the screen stays black it probably needs new capacitors, if there is no light try fuse and other socket.
6/6/2016 12:37:17 AM • Apex Digital... • Answered on Jun 06, 2016
2answers
I have a apex tv model:LD4088 it powers on but the
check to make sure that your tv is not starting in "line in" mode and to be starting in the tv mode.
if the screen flashes then goes out then you have a back light problem and it needs to be serviced! possible bad power inverter for the back lights
6/5/2016 2:53:50 AM • Apex Digital... • Answered on Jun 05, 2016
Can you help me with my tv problem
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
4/3/2016 6:29:37 AM • Apex Digital... • Answered on Apr 03, 2016
My TV keep turning it self off and some time it urns back on by itself.
main power supply regulator section faulty. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
4/2/2016 6:34:22 PM • Apex Digital... • Answered on Apr 02, 2016
2answers
My TV cuts itself on and off so can you help me or not
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
4/2/2016 6:34:00 PM • Apex Digital... • Answered on Apr 02, 2016
Bought a sony remote and it will not pick up you codes listed. need code for apex
Sony remote control have no set-up code to Apex brand devices. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
2/26/2016 8:04:25 AM • Apex Digital... • Answered on Feb 26, 2016
Is the main board bad on my TV?
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Fault at its main digital board. Short circuited component/s at it.
1/17/2016 7:52:41 AM • Apex Digital... • Answered on Jan 17, 2016
I'm trying to hook up a 2-3 year old APEX Digital TV that I bought from a friend. I've gone through the set up options, but cannot get any volume at all. Any suggestions how to fix this?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1/17/2016 7:38:23 AM • Apex Digital... • Answered on Jan 17, 2016
Apex Digital LD4088 LCD TV Logo
288 questions posted
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Apex Digital Televison & Video
Most Popular Question
dont remote apex tv trying change input
  • Televison & Video
