20 Most Recent Vitapur Energy Star Bottom Load Water Dispenser Questions & Answers
Sorry, I forgot to mention I am talking about a Vitapur Water Dispenser. It is brand new.
Question moved from Refrigerators category to one of the 10 Vitapur categories listed by MODEL number. What you wrote here should be under my Answer to you yesterday by clicking Comment under it. https://www.fixya.com/support/t29938275-get_solid_blue_light_but_no_cold_water If it is brand new, it is under warranty. Did you read the manual. Did you put water in it? Did you Prime it by pressing the tiny hidden button in the cabinet? Bottom Mount, Top Mount? Model Number so I can read the manual for you? :>D Give me the answers under here. ..
11/1/2023 3:05:00 AM • Vitapur Energy... • Answered on Nov 01, 2023
Vitapur Water Dispenser. How to replace cold water thermostat on a Vitapur
Question edited for clarity. Question moved from Cars and Trucks category. Try adding the model number to this search query https://www.google.com/search?q=vitapur+replace+cold+water+thermostat All question need 'make model (what it is)' as the first three words in every question please ..
7/24/2022 10:50:43 PM • Vitapur Energy... • Answered on Jul 24, 2022
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
1/2/2020 8:47:32 PM • Vitapur Energy... • Answered on Jan 02, 2020
My hamilton beach Top cooling Water Dispenser Model Number Tl-1-2 is not cooling water a few hours ago The motor is constantly working,however, the blue light not switched off Please advise
A few troubleshooting steps you could try: Check the Power: Ensure that the unit is properly plugged in and the circuit breaker hasn't tripped. Check the Cold Switch: There should be a cold switch on the back of the unit. Make sure it's in the ON position. Temperature Limiter: It's possible that the temperature limiter may have tripped. You can try setting the hot and cold power switches to the OFF position, wait five minutes, then set the switches to the ON position. Wait 30 minutes for the water to heat or cool. . Mineral Build-up: If the dispenser has been used for a long time, there might be a mineral build-up in the tank that could be clogging it3. You might need to clean the dispenser to remove these deposits. If none of these steps work, it might be best to contact Hamilton Beach customer service for further assistance
4/18/2024 2:03:49 PM • Water Filters &... • Answered on Apr 18, 2024
2answers
I have White particles coming out of my 5 gallon water cooler. I cleaned the cooler with the manufacturer's (Avalon) cleaning kit but the particles are still there
You may have spotted white and black flakes in water in the past. White flakes are created by mineral deposits from hard water, whereas black ones are caused by mold that develops in your water dispenser.
9/1/2023 7:54:45 PM • Water Filters &... • Answered on Sep 01, 2023
My hamilton beach water cooler is not dispensing any water. Model BL-5-2
There are multiple possible causes. Check pages 12-14 (PDF pages 13-15) in the manual: https://useandcares.hamiltonbeach.com/files/840178600.pdf Note: if you hear the refrigerator unit running or feel heat at the hot water tank, you have power. Not listed in the troubleshooting guide in the manual: pump or valve unit failure. I don't see anything on venting for the water bottle either, so in addition to the steps in the manual, do a check of any venting on the bottle attachment assembly for clogging.
3/21/2023 4:56:07 PM • Water Filters &... • Answered on Mar 21, 2023
2answers
Viva bottom loading water cooler does not dispense water
Some others addressed this issue on Fixya.com before: Brett 42 said: the water line is froze.. I took a hair dryer and applied it directly to the dispenser for about 10 minutes. I then held down the buttton for approximately 30 seconds and the water began to drip extremely slowly then faster until a small chunk of ice shot out of the dispenser. I believe the reason this happened was that I the temp of my freezer set lower than the fatory setting. Mike Smith said: "1) remove the tubing connector behind refrig kickplate . Press for water . If no water comes from tube under refrig , then possibly frozen tank but probably not . Probably bad water inlet valve . ( tank is in the lower potrion of the refrig section behind the crispers ) . 2) if water does shoot out , then your freezer door is frozen which requires leaving door open and tapeing light switch closed and tape plastic around freezer section opening so fridge will continue to operate normally . Thawing freezer door could take a day or 2 . 3) You can plug the hoses back togather and walk by occasionally pressing water untill comes out . Lower your freezer temperature setting also ( could be set for too cold)" I hope this helps you out!
10/13/2022 11:23:44 PM • Water Filters &... • Answered on Oct 13, 2022
The blue button on my Pimo water cooler is stuck in?
put some olive oil on the blue button and try to press many times in and out
9/8/2022 2:41:15 PM • Water Filters &... • Answered on Sep 08, 2022
Hamilton Beach Bl-1-3 water cooler
You are my 40,000 question that I have answered! You don't get a prize, but I think that is pretty neat Paul :>D I have been here a long time. The manual only says that you have to make sure that cooling is switched on (Page 12). The unit has a 1 year warranty. If it out of warranty, you just need to pick it up and take it to a refrigeration engineer. It may need topping up with refrigerant gas. Consumer Support Questions? How to contact us: Telephone 800-488-5080 (Monday - Friday 8:00AM-5:00 PM ET) E-mail: [email protected] [email protected] https://useandcares.hamiltonbeach.com/files/840178600.pdf There are some videos here that might be of interest. https://www.google.com/search?q=Hamilton+Beach+Bl-1-3+water+cooler+not+cooling+the+water Hope the information helps you. ..
9/17/2021 10:14:37 PM • Water Filters &... • Answered on Sep 17, 2021
I need a manual for an oasis water cooler model BPA1SHS
Contact Oasis to request the manual.
1/23/2021 10:47:24 PM • Water Filters &... • Answered on Jan 23, 2021
I have a HB Water cooler Model 2312C,...I need a replacement support collar...please help!
CHECK YOUTUBE SEARCH AS I found Hamilton cooler.
11/25/2020 8:15:52 AM • Water Filters &... • Answered on Nov 25, 2020
2answers
How do I find the hot water reset button on my Hamilton Beach 3-temp bottom-fill water cooler?
How to Set the Temperature on a Primo Water Dispenser
  1. Move the Primo water dispenser away from the wall, being careful not to tip or spill the water bottle.
  2. Locate the flat, brass-colored screw on the back of the water dispenser.
  3. Turn the screw slightly clockwise for colder water or counterclockwise for warmer water. ...
  4. Check the temperature of the water.
4/10/2020 11:56:05 AM • Water Filters &... • Answered on Apr 10, 2020
2answers
No water coming out of water filter
Please share the make and model of your filter.
2/10/2020 1:06:09 PM • Water Filters &... • Answered on Feb 10, 2020
My water cooler is not dispensing cold water. The water is room temp, how do I fix it
press the rest button or get a new cooler as the compressor is not working
1/28/2020 1:46:06 AM • Water Filters &... • Answered on Jan 28, 2020
Vitapur Energy Star Bottom Load Water Dispenser Logo
14 questions posted
Top Vitapur Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Vitapur Water Filter and Cooler Expert? Answer questions, earn points and help others
View Most Popular
  • Vitapur Water Filters & Coolers
Most Popular Question
not sucking up water
  • Water Filters & Coolers
