20 Most Recent
Singer 9960 - 9960 Quantum Stylist Questions & Answers
Singer 9960 automatic thread cutter not working
I'm looking for a solution to why the thread cutter isn't working. It just pulls the thread into a knot and jams the bobbin case. I was hoping for an answer here but the answer had nothing to do with the question!
Upper thread keeps breaking
I have this problem too. I have traced the problem to a design fault in the thread path. The thread wares a groove in the casing and snaggs the tread causing it to stretch and break. When it breaks it releases so it took me a long time to locate this problem. I have just contacted Singer and am awaiting their response. (See photo)
it is my belief that this problem is responsible for needles snapping and a host of other issues.
I hopes this helps. It should be an easy fix, it just requires a metal plate to cover the grooves cut by the thread.
Troubles with the bobbin tension on the singer quantum 9960
the small flat spring on the bobbin holder under which you pull the thread is the tension setting for bobbin thread
it extremely delicate and just a partial turn of the screw that holds that spring in place has a large influence on the tension
mostly problems here are that the needle tension is insufficient and causes the problems
