20 Most Recent Sperry Instruments DM6450 64 Series Digital Multimeters Questions & Answers
Why does my sperry DM6450 multimeter read "connect
Are you connecting your leads to the proper terminals on the meter? There are, what, four of them? Easy to mix up. If it still isn't working, then you might have a bad connector on your multimeter.
1/16/2019 8:43:38 PM • Sperry... • Answered on Jan 16, 2019
Replace battery on sperry dm6400 multimeter
remove battery door and replace 9V battery detailed explanation bellow http://www.testequipmentdepot.com/sperry-instruments/pdf/dm6400.pdf
12/23/2016 9:18:10 PM • Sperry... • Answered on Dec 23, 2016
0answers
0answers
0answers
Vh 601a
Be the first to answer 4/22/2012 11:44:02 PM • Sperry... • Posted on Apr 22, 2012Be the first to answer
0answers
What does "open neutral" mean?
The "neutral" wire in home wiring is always the "white" wire. The hot line is always the "black" wire or in the case of a multiple conductor, can be just about any color but white or green. Green is circuit ground, the nasty 3rd pin on the plugs we use, but a very important safety feature.
When you have an "open neutral" reading it means that the "white" wire has come loose some place in your wiring. A broken or loose wire is referred to as an "open" in electrical terms. I assume you are plugging an outlet tester in and get this indication. It may just be in the outlet you are testing or someplace else between the outlet and the circuit breaker.
10/4/2010 8:57:52 AM • Sperry... • Answered on Oct 04, 2010
GFCI Outlet Tester shows all three lights on
I had one do this and I had to install a new one due to the other one being faulty internally
9/1/2009 1:03:42 AM • Sperry... • Answered on Sep 01, 2009
2answers
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
4/17/2024 8:59:53 PM • Measuring Tools... • Answered on Apr 17, 2024
Rf tech 433mhz manual model 217S31
I want to use an old sensor forgiven during 30 years. I have no more manual, off course. Thanks for your answer
3/26/2024 11:42:40 PM • Measuring Tools... • Answered on Mar 26, 2024
What are the readings on a meoisture meter measured in?
Most moisture meters measure the moisture content of wood or concrete is measured in percentages. So if the reading says 15 that means that there is a content of 15% moisture in the concrete.
3/16/2024 7:34:55 AM • Measuring Tools... • Answered on Mar 16, 2024
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
2/19/2024 4:57:31 AM • Measuring Tools... • Answered on Feb 19, 2024
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
1/21/2024 4:20:12 AM • Measuring Tools... • Answered on Jan 21, 2024
DSE Z111 Weather Station: Is the wireless sensor available for sale?
Unlikely unless you know the secret maker name and can find them in China. At the moment, no one has heard of it apart from here on Fixya. All questions need FULL 'make model (what it is)' please. https://www.google.com/search?q=dse+z111 ..
1/20/2024 1:59:56 AM • Measuring Tools... • Answered on Jan 20, 2024
How can I adjust the time on my weather station model #sgr72914?
  1. Access the Time Setting Mode:
    • Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
    • Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
  2. Adjust Hour and Minutes:
    • Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
    • After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
    • Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
  3. Confirm the Time:
    • Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
  4. Check the Time Display:
    • After setting the time, check the display to ensure that the time is displayed correctly.
1/7/2024 9:28:03 AM • Measuring Tools... • Answered on Jan 07, 2024
Starrett Tape Measure. Can I Replace a 1.5 volt Battery with a 3.0 volt Battery in it?
Question edited for clarity. Question moved from Motorcycles category. Of course not! You will burn out all the electronic components. You can't just double the voltage. Conversely you can't put a 1.5 volt battery in place of a 3 volt one. Get the proper battery. https://www.starrett.com/contact-us# ..
12/20/2023 4:55:24 AM • Measuring Tools... • Answered on Dec 20, 2023
Sperry Instruments DM6450 64 Series Digital Multimeters Logo
2 questions posted
Top Sperry Instruments Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sperry Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Sperry Instruments Measuring Tools & Sensors
Most Popular Question
replace battery sperry dm6400 multimeter
  • Measuring Tools & Sensors
