20 Most Recent Tissot T-Touch T33759851 Questions & Answers
My Tissot touch will no
In this watch the battery should be changed after one year, depending on how often the features are used. After changing the battery the all reset should be done. Best to take it to an authorized service, and not any non authorized place to change the battery. Get in touch with Tissot for the info about where to bring the watch.
1/13/2021 4:30:42 PM • Tissot T-Touch... • Answered on Jan 13, 2021
4answers
Battery Change on T-Touch
there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
12/16/2019 6:34:59 PM • Tissot T-Touch... • Answered on Dec 16, 2019
The temperature messure stay's at 89.3 C sure the display
Are you wearing it? Only reads proper ambient temp when off your wrist. Otherwise it is reading body temp.
7/17/2016 9:25:32 PM • Tissot T-Touch... • Answered on Jul 17, 2016
2answers
T-touch dont display altimeter, meteo and thermo.
I have the same problem with my t touch one, the first model with round push button, after take it to a battery replacement and service, and ask a tissot representative store, I receive two answers and both says that I have to change the movement... means ... the machine, and if is under warranty will be free, is maybe 6 or more years old so no more warranty, sad but true, I let it be. I will not spend at least 400 USD. to do it, so, try to enjoy the rest of functions left and a nice looking watch.
11/12/2015 11:48:12 PM • Tissot T-Touch... • Answered on Nov 12, 2015
4answers
Tissot t-touch analog time is out of sync with
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
1/25/2015 6:59:47 AM • Tissot T-Touch... • Answered on Jan 25, 2015
6answers
Synchronizing the manual and digital clocks
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock Incrementation of the minute hand(3 steps=1 minute) Incrementattion of the hour hand(3 steps=1 minute) Press the middle button to validate the setting.
10/31/2014 8:52:31 PM • Tissot T-Touch... • Answered on Oct 31, 2014
Reset a tissot t touch
10/12/2014 12:21:53 PM • Tissot T-Touch... • Answered on Oct 12, 2014
Haw to reset tissot t tuch
If you syncro you must touch the center until the option look open the press the middle button for 5 sec and you see the function Synchro.You must set the 2 hands at 12 exactly.greekdimis.blog spot.
8/28/2014 12:03:25 PM • Tissot T-Touch... • Answered on Aug 28, 2014
tip
Replace Battery on a Tissot Touch
When you need frequent re.Syncronizing of your Touch or after 2-3 year
maybe you need to replace the battery.
you need:
a CR1632 3V Battery (about 2€)
a very tiny screw driver
a very sharp knife
With the knife remove the bottom of yout Tissot, (you do not need to unscrew) it's just a cover to pull up like in this imagedcef0c0d.jpg
Now you can clean with a soft brush & remove the dust.
Use the screw drive to replace the battery,
put back the cover & enjoy
2answers
Name and battery number
Renata CR1632
http://www.renata.com/pdf/3vlithium/CR1632_v06.pdf
To replace battery you need to have very small screwdriver and some knife to open back cover.
5/20/2014 8:20:10 AM • Tissot T-Touch... • Answered on May 20, 2014
2answers
My tissot toch hour and minutes are out of sync
This is an expected, needed adjustment, and is addressed in the manual:
http://www.tissot.ch/data/usersmanual/138-en.pdf
Syncronisation
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
5/20/2013 9:19:35 PM • Tissot T-Touch... • Answered on May 20, 2013
2answers
The digital and hands display different times on my Tissot Touch
5/14/2013 8:34:56 AM • Tissot T-Touch... • Answered on May 14, 2013
My Tissot T-Touch Altimeter does not function.
Mine did the same thing; I read in other blogs that this could happen due to humidity. I heat up my watch with my wife's blower for about 5 minutes on high. After 5 min I couldn't even touch it! The screen went blank. After a few minutes when it cooled down the screen came back up and to my amazement all the function came back. it is risky but So far... it works well.
1/31/2013 5:22:59 PM • Tissot T-Touch... • Answered on Jan 31, 2013
2answers
Showing 6ae on my Tissot T touch. Also cannot
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
12/13/2012 9:31:59 AM • Tissot T-Touch... • Answered on Dec 13, 2012
2answers
Need to replace battery on
This can be difficult(read dangerous to your watches health) to do if you don't know how. I paid 700 for mine and would not try to save 10 bucks doing it myself versus destroying my own watch, take it to a legitemate watchmaker. He will also inspect gaskets and will have the proper tools and most importantly will know what he is doing.
12/13/2012 6:05:09 AM • Tissot T-Touch... • Answered on Dec 13, 2012
My T touch is not responding
Even I see the same. But I got this repeatedly to the Authorised Service Personnel of TIssot in India. But this never got fixed. Anyways thanks for the guidance. CheersMadhu
11/9/2012 1:01:17 PM • Tissot T-Touch... • Answered on Nov 09, 2012
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
10/8/2012 10:57:34 PM • Tissot T-Touch... • Answered on Oct 08, 2012
Tissot Touch extreme stopped after a minor fall
may need to be reset, re instal battery. battery life is 4 yrs.
4/4/2012 1:43:56 AM • Tissot T-Touch... • Answered on Apr 04, 2012
Fix the hands correct with the dejital
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are;
hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t
have the hands exactly opposite etc. This can all be fixed. The Synchronization
function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
10/2/2011 2:24:50 AM • Tissot T-Touch... • Answered on Oct 02, 2011
Where can i buy replacement
Where is cebu?
5/24/2011 6:51:52 PM • Tissot T-Touch... • Answered on May 24, 2011
Tissot T-Touch T33759851 Logo
167 questions posted
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
T Tissot
  • T Tissot
Most Popular Question
tissot t touch analog time out sync
  • Watches
