Cars & Trucks Logo
Posted on Jun 28, 2011
How does a Plymouth breeze drive on long distance travels. ??
A
Anonymous
That's a ten year old vehicle isn't it?
Not a top of the line car to begin with
I don't know, but I wouldn't buy one
Should be a Mitsubishi in there,you
don't want that. The timing belt will go
the second day you have it & the transaxles
are junk
My 1999 Plymouth Breeze when idle the Gage Norma when driving the 2 miles an hour at 60 miles an hour temperature gauge indicates on the low level way to cold my heater in the car gets cool? Why
Hello your problem is simple if it is just sitting there running and you have heat but if you drive it and you lose heat it is the thermostat, it is stuck open and the fluid is passing threw the motor to fast to heat up. get a new thermostat and problem will be fixed
List Search 1999 Plymouth Breeze Reilly Auto Parts
What is fault code 17 on a 1997 Plymouth Breeze with 2.4 liter engine?
How did you come up with code 17 on a OBD2 vehicle ? Should be a P0117 .
2answers
My 1996 Plymouth Breeze is stalling. I can press
Try changing the fuel filter. It may have been clogged. If this was at all helpful, please rate. Thanks for asking.
I have a 99 plymouth breeze. My friend was
You may need to install shims between the starter.
Bogs down after driving distances
Your catalytic converter may be bad.
3answers
Car shuts off sometime while driving
SOunds like an alternator problem
1999 plymouth breeze rom's running high
does it idle high also? i've had that problem, when i start the car (same as yours) it idles at 4.5rpms and after twenty minutes of driving for some reason goes to normal, i was told its a rpm sensor problem. good luck.
Top Plymouth Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Plymouth Expert? Answer questions, earn points and help others
