Buttons are numbered as followed: Start/Stop is button 1 Lap/Rst is button 2 Indiglo is button 3 Mode is button 4
a) Press 4 to select "TIME" mode b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink. c) Press 1 to reset digits to 00. d) Press 4. Minute digits blink e) Press 1 to set minutes. f) Press 4. Hour digits blink. g) Press 1 to set hours. h) Follow same patter to set day of month, month, etc... i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
Press the MODE button until you get to the AL (ALARM) screen. Press Start/Split (Stop/Reset) (upper right button) repeatedly to turn the alarm and chime are off. If that did not help the manual can be found at www.timex.com at the bottom of the page click on manuals/downloads, click on manual downloads go to Digital Chrono/Alarms/Timers and click on the manual. Hope this helps.
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears. 2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing. 3. Use StART/Stop to choose among seconds, hours, and minutes, and 4. Use ADJUST to increase the selected number 5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
hold down the "adjust" button (bottom right) as you press the "start/stop" button (top right). this will cycle through the alarm functions. I believe one is an hourly chime and the other is the alarm. just keep pressing until there are no icons below the time. that should do it.
