An LD code n a Kenmore machine means Long Drain. Check the water inlet hoses for kinks or clogs. check the filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked.
LD is a long drain code usually mean something is in the drain line or pump area. Check thes areas first. If nothing blocking them then the pump is going out.
Ld flashes when the water level does not change after the drain pump is on.
? Is the drain hose or the drain pump clogged?
? Is the drain hose height greater than 96′?
LD means long drain. There is a problem with the draining part of the cycle. You might be over sudsing or the drain hose is too low. Let me know if this helps.
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
