Washing Machines Logo
Posted on Dec 01, 2017
I have a washingmachine - AEG Lavamat 76819. Its 4-5 years old. Today it stopped in the middle of a cycle - totally dead. Is there a fuse in this model that may be need to be replaced? I cheched the filter and the fusebox in the house, it all appears to be ok. I have a 6 year old who keeps this machine going...HELP!!!
Tadej Miklavi
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 28 Answers
  • Posted on Dec 03, 2017
Tadej Miklavi
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
28
Questions
Helped
7010
Points
86
No fuse inside any home washing machines. As far as I know. Motherboard probably
2 Related Answers
Anonymous
  • 174 Answers
  • Posted on Jul 24, 2010
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Anonymous
  • 15935 Answers
  • Posted on Sep 16, 2010
SOURCE: How to deactivate EFO on
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
AEG washingmachine LAVAMAT 74825 after years of brilliant service its showing errorcode E60. Whatcan I do to rectify or if I need to call a service engineer what is the telephone number please. Thanks
This sounds like it is the heating element in the machine. Check to make sure the heating element is getting power. If it is then replace the element.
1helpful
Hi my AEG OKO-LAVAMAT 88830 is about 10n years old. Today I was cleaning my machine. I filled the machine up with water on the rinse cycle then turned it to pump. I did this a few times as I have had a...
According to my list for AEG Lavamat washers, 'C3' stands for 3 possible causes 1 'safety flood device operated' (I suspect it means that it has sensed some water in the bottom tray. Not an easy job to do but I would check for a leak underneath), 2 'pump fault' and 3 'module fault'. Sorry I can not be of more help ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
6helpful
How to deactivate EFO on Lavamat 76819?
23helpful
2answers
Have Aeg 72630 stopping problem
When it sticks, is the tub empty of water? If so then you may need to change the cold water solonoid just inside machine where fill vaulves are fitted. good luck hope this works
3helpful
2answers
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Top Washing Machines Experts
john h
