SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
read this site: http://www.askanowner.nl/qa/view.asp?s=2&qid=152459&arrqueryparts=&arrquery=code%3Bce kind regards, w vd vegt
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
tried unplugging the connectors to the door interlock switch then attaching it again then tried to power on the machine but no lights on the panel but as i turned on the selector knob the machine starts up but i can see the timer set to 139 flashing then the start/pause intermittently blinks green then off,, then the pump continous to function all the water coming in is continously beng discharged/draines out.. what could be the
