I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
