I have your solution guaranteed, I fixed mine yesturday remove H L screw plastic caps and on high 11 threads exposed and on the low side 8 threads exposed. removing the plastic caps allows u further adjusting these wear out or move soo just take them things off and you will be rolling
Testimonial: " Thanks, I removed both needle valve stems, cleaned and sprayed out seats with carb cleaner. Reset at 1 turn out from fully closed position. "
Thanks, and I removed both needle screws and cleaned out with carb cleaner, and reset, runs like a top.
perfect good job you did it
