SOURCE: aeg 76669 oko lavamat machine not
can you switch back to off - then to orginal programme - only the start light may show - what i did then was press all of the 4 button for rinse, spin short wash and held them in place - fro upto 10 secs - machine seemed to reset itself and it worked
SOURCE: Washing machine door lock problem
hello nesbit,
i think you could have a problem with the pause button, it is what it is doing, pausing the machine, un locking the door so that you can add clothes or what ever. could be that the button is triggering the signal while vibrating during wash cycle.
take a closer look at the buttons, feel if you have this clicking feeling that all buttons should have. compare the other buttons as you press them.
you might need a whole touch pad to replace if you will find the problem there.
tnx 4 using fixya,
drcool
SOURCE: AEG OKO-Lavamat 1271 VI Turbo
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
