Briggs & Stratton Prosumer 2800 PSI (Gas - Cold Water) Pressure Washer - 20324 Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When adding SAE 30 oil to new pw, do we add to the pump reservoir only or do we also add to the two oil inlets on either side of the engine housing?
  • rick huisman
    rick huisman Apr 21, 2018
    check our manual or fone dealer
  • ray012965 Jul 03, 2018
    10w30 hd for engine 15w40 hd for the pump fill to half of sightglass of pump fill engine to end of fill neck
Anonymous
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on Mar 03, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
257
Questions
Helped
347635
Points
772
From what i've read in the manual you need to fill both the pump and the motor. The pump itself will have a dipstick, the motor gets filled to the top. If the motor has two inlets one should fill up when you pour in the other side. Most briggs had two motor oil inlets so the motor could be used on several types of equipment. The pump itself should use about 9.6 oz
curtis12451
Level 2:
New Friend:
  • Expert 90 Answers
  • Posted on Jan 07, 2015
curtis12451
Expert
Level 2:
New Friend:
Answers
90
Questions
0
Helped
1073380
Points
368
You need to fill both the pump and the motor. The pump itself will have a dipstick, the motor gets filled to the top. If the motor has two inlets one should fill up when you pour in the other side. Most briggs had two motor oil inlets so the motor could be used on several types of equipment. The pump itself should use about 9.6 oz
How to check oil on honda gx160
There is an oil dipstick on the side of the engine. Remove the dipstick and check the oil on the dipstick.
The oil should be about half way up the threads on this engine.
If you need to add oil you can use SAE 30 or a 10W30 Oil.
Mar 28, 2012 • Garden
3helpful
Where do you add the oil on a DeWalt 3100psi pressure washer?
Hi and welcome to FixYa, I am Kelly
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Thanks for choosing FixYa,
Kelly
3helpful
There are 2 different places to add oil to my 3500 Honda engine pressure washer (cold). Do I use SAE 30 for the motor oil and gear oil for the other oil?
you can use sae 30 in the motor and hydraulic oil or gear oil in the pump.
just note that there may be two oil filler holes on the motor.
1helpful
2answers
What is the Recommended oil weight for 1987 2.8 v6 fiero
1987 PONTIAC FIERO 2.8L 6-cyl Engine Code [9]
All TEMPS......5W-30 SAE 5W-30 is preferred.
CAPACITIES: Engine, without filter..........3.8 liters, Add extra oil when replacing filter. After
refill check oil level.
Oil Drain Plug.....15-20 ft/lbs
Thank you for using fixya and good luck
1helpful
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
7helpful
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 • Garden
Need to put oil in and don't know what kind of oil to put in or if it's gas oil mix????
ADD SAE 30 SMALL ENGINE OIL. 18oz TO 20oz
SEARS SALES A 20oz BOTTLE OF CRAFTSMAN SAE 30 OIL FOR $2.59
1helpful
How many ounces or quarts of oil do you put in the engine and what kind when changing the oil?
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
1helpful
2answers
What type of oil do I use 1850 pm0401850
Oil Type. Use new good quality oil such as SC, SD, and
SE grades. The oil to be used depends upon the temperature
at which the engine is operated:
Summer: (temperatures of over 40 degrees F/10 degrees
C) SAE 30 or SAE 10W-30, SAE 10W-40
Winter: (temperatures of below 40 degrees F/10 degrees
C) SAE 20 or SAE 10W-30
Manual here:
http://www.powermate.com/pdfs/2007/11/12/pm0401850-52.pdf
2answers
Needs oil what weight do i use?
If your engine is a 4.0 it uses 5w-30
If your engine is a 5.0 it uses 10w-30
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
