Hi!!
Click on the following link for a diag. of the control panel. to get access to the back of the Control Board http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0901032-00003.png
check that wiring harness (#8) connections to the Electronic Control Board are tight and the wiring is not broken, burned or damaged. Disconnect the Unit and feel the wire harness (#8) for any small bumps or deformities, repair as needed.
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
I have a Maytag epic z front loader model # MHWZ600TB01 it reading to much suds I clean it out but how you take the hose and coin trap and the other piece that is connected to right of the long drain pipe
