SOURCE: saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
SOURCE: vista
alright i believe i have found a good working vista driver for the logitech attack 3 to get it please follow this link. sure hope this works for you.
if this was not helpful please do not hesitate to re post and let us know.
Regards: PC Pro
SOURCE: installed joystick extreme 3d pro wiil not work
Sometimes on those games, if you used a mouse originally, they do not auto-detect that ur using a joystick now - go into the options tell the game ur using a joystick and also there you may be able to set custom control features (what button does what).
Please let us know how it went.
**.The best way to acknowledge contribution is to rate it's relevance.**
SOURCE: joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
SOURCE: MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
