Hi, I'm trying to plug a AEG-Electrolux Lavamat 74800 into a converted outlet (110V to 220V) in Mexico, following a relocation to this country. Bought the washing machine in Germany which runs at 50Hz vs 60Hz in Mexico. E60 keeps showing up, also on the dryer. Is this due to freq?? Checked the electrical installation already twice to ensure adequate voltage and grounding. Called AEG-Electrolux service and they mentioned freq should not be a problem... Thanks for your help! PabloHi, I'm trying to plug a AEG-Electrolux Lavamat 74800 into a converted outlet (110V to 220V) in Mexico, following a relocation to this country. Bought the washing machine in Germany which runs at 50Hz vs 60Hz in Mexico. E60 keeps showing up, also on the dryer. Is this due to freq?? Checked the electrical installation already twice to ensure adequate voltage and grounding. Called AEG-Electrolux service and they mentioned freq should not be a problem... Thanks for your help! Pablo
Can you tell me where the reset button is pleaseCan you tell me where the reset button is please
AnonymousMar 13, 2014
My washing machine showing error code bE what does it meanMy washing machine showing error code bE what does it mean
AnonymousMar 15, 2014
The display shows code AEO and continuous acoustic alarm. Machine stops when allarm occurs, indicating that washing cycle is finished.The display shows code AEO and continuous acoustic alarm. Machine stops when allarm occurs, indicating that washing cycle is finished.
This is an Aeg Lavamat machineThis is an Aeg Lavamat machine
You can't post conmments that contain an email address.
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Error code E6H on your AEG Lavamat washing machine typically indicates a problem with the heating system. It may mean that there is a problem with the heating element, the temperature sensor, or the control board. It's best to refer to the manual for your specific model for the exact meaning of the error code and for further instructions on how to resolve the issue.
If you are unable to resolve the issue yourself, it is recommended that you contact a professional repair service for assistance. Attempting to repair a washing machine can be dangerous and may void your warranty if not done properly.
In the case of insufficient heating appears error code E60 what means replace the NTC sensor. Exclude heater, PCB or relay malfunction because you indicate that the machine is heated to 50 degrees Celsius.
Please remove the power plug and depress all the buttons on the panel, while the power plug is inserted and power switched on , press on the start/pause/stop. it must restart the controller unit or there can be external or internal errors as designated by E60. Check the door switch,drain pump and inlet flow.
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
