I live in the UK and my Sony camcorder no longer produces am image in the camera mode or memory mode for both the LCD screen and in the view finder. Is there a UK Sony service URL that addresses this problem. Many thanks.
Paul in Kent
Many thanks!! Sony told me to mail it to them and will repair free of charge.Many thanks!! Sony told me to mail it to them and will repair free of charge.
Nothing appears in the LCD sreen when I switch it on, but I can see in the view finder......Nothing appears in the LCD sreen when I switch it on, but I can see in the view finder......
You can't post conmments that contain an email address.
Hi obx4ever, If this helps, the CCD was a problem I had in a lot of those camcorders and only replacement cured the problem. Only a sony authorized service centre will be able to replace the CCD for you. The CCD is a closed coupled device which generates the image that you see in the eyepiece and LCD screen when in picture mode. Michael.
Hi, If camcorder does not show live view in camera mode then most probably its ccd imager chip failure problem that part need to be replaced to get live image in lcd/ view finder to get it record on tape. Let me know exact model number of your camcorder to provide you more info. Thanks.
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
To my understanding that you do not see live view in camera mode to record and camcorder playback old recorded tapes correctly and you get picture in LCD. If it is true then please check lens cover that need to be slide down to get live view in camera mode. If problem still exist then 2 possibilities, either aperture in lens mechanism is bad or ccd imager is defective. In that problem, camcorder needs qualified tech to fix it. Let me know any further query.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD. If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor. Qualified camera tech will replace ccd imager chip. Thanks.
Based on the information you have provided, it appears that you may have encountered this issue. To determine if the CCD (image sensor) is working properly, please follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe the LCD.
a. If the images are displayed properly, please proceed to step four.
b. If the images are not displayed, or a "NO IMAGES" message appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode (i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or viewfinder. If the scene the camera is pointed at appears on the LCD and/or viewfinder, the CCD is operating properly. If the LCD and/or viewfinder remain black, the camera requires service
Hi, Let me know bit detail of problem... You can not see live view on LCD and view finder in camera mode and can playback old recordings and picture result is OK, If yes, then its bad ccd imager problem and ccd imager will be replaced.
DCR-TRV265E is PAL camera and I assume that you are in UK.
Here I provide you information to save 400 or some thing. Sony will repair ccd imager problem free of cost. You can have details on Sony CCD Support.
Does your camera playback old recordings fine? and just can't show live view to record? If yes, then camera has problem of bad ccd imager and this part will be replaced. Sony announced free of cost repair scheme for subject problem. DCR-HC20E is PAL system camera so Sony Support UK can be visited for free of cost repair details as your camera model is listed there. If you live in different country, let me know to guide you further. Thank you.
*************there will be rough stretched shapes occassionally. But mostly it looks like a black screen with flickers of white lines. If I record like this the image comes out exactly as seen***
A defective CCD.
