Re: did you ever get a response about your kenmore elite...
The F2 error code on your microwave oven is a membrane failure. It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Error code ERROR 1 presents on Kenmore Elite countertop microwaves with model numbers 56561582011, 16755, 56561584011 or 56561589011. ERROR 1 occurs when the unit has not received enough power to undertake a sensor cooking operation. Sensor cooking is a feature of Kenmore Elite microwaves that adjusts the temperature and cook time of dishes contingent upon information received by sensors in the microwave. In order to perform this function, a microwave must be plugged into a power source for at least five minutes previous to doing so. Thus, ERROR 1 indicates that the unit has not been plugged in for a sufficient length of time.
Check to see if the touch panel is connected to the main board via a ribbon cable. If it is, carefully remove and clean the end that attaches to the circuit board. Electronic contact cleaner works well for this.
Sounds like a bad touch panel. They run silver oxide traces through that panel and they couple a lot of them together. So if a trace common to those pads breaks you lose all the pads connected to that line So Probably need to get price and availability on a new touch panel.
f2 error means :------- 1. The oven temp has risen above 665F and the door is not locked or 2. The temp has risen above 965F with the door locked-------------if this happens you should check:----------- 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits 2. Check and replace oven temperature sensor if necessary keep updated,please do accept and rate the solution.thanks.
try opening up the control panel,disconnect the connector ribbon coming from control panel and connected 2 control board by just pulling it out and cleaning end of connector ribbon and iserting it back.some times this works.if not then 4 sure touch panel needs to be replaced.
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
