Sorry to read about your problem, I hope this helps you out.
Your E20 code
This
particular code is used when the machine detects a pump problem or
water draining problem (failure to properly pump all the water off in
the designated time). In this case, the fault would occur
just before
attempting to spin.
Check your filter which is accessible from the bottom of the machine.
Sometimes intermittent FALSE errors like this can come up if there are
high resistance (oxidised) contacts between the ribbon cable that goes
from the POWER CARD to the facia panel electronics. To fix that sort of
problem, remove any retaining clips from the end that plugs into the
facia panel, remove and replug the cable end a few times. This gives the
contacts a "wipe-clean" action and can remove the oxide. Obviously if
the cable or contacts are badly corroded or burnt, then replace it.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
