Dryers Logo
Posted on Nov 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have AEG Lavatherm T-300-W dryer and it is not drying anymore. I checked front door filter and it is ok. Is it thermostat or blower problem? Thanks, Tom
Marius van der Walt
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 02, 2012
 Marius van der Walt
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
7257
Points
9
If it spins, it's your element...but if its your element, it could just be your thermal fuses...which can be repaired rather than replace the whole element which is very expensive. [email protected] or www.handyman.co.za
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on Nov 28, 2010
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
823728
Points
9577
Http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Aeg lavatherm T7000 series tumble dryer how do i enter the test/diagnostic mode?
https://www.google.com/search?source=hp&ei=Z3V3XoflApPAgweA9rGoCQ&q=Aeg+lavatherm+T7000+series+tumble+dryer+how+do+i+enter+the+test%2Fdiagnostic+mode%3F&oq=Aeg+lavatherm+T7000+series+tumble+dryer+how+do+i+enter+the+test%2Fdiagnostic+mode%3F&gs_l=psy-ab.3...2693.2693..21300...0.0..0.214.421.2-2......0....2j1..gws-wiz.....6..0i362i308i154i357.sBeLMEZ-gtM&ved=0ahUKEwjHtK7ZpK7oAhUT4OAKHQB7DJUQ4dUDCAU&uact=5#kpvalbx=_yHd3Xq2xK8vLgwfQuoDYCQ25
Mar 21, 2020 • AEG Dryers
My aeg lavatherm 37320. Fluff is blowing back into the drum when drying.
You need to clean the inside of the dryer. A shop vac up the exhaust vent is the easiest way. If your hands are small enough you can reach i. There and clean it out. Obviously unplug the dryer first.
Sep 10, 2016 • AEG Dryers
My AEG dryer lavatherm Apperars dead although receives power, the thermalfuses checked OK ( continuity) Is there an additional fuse or the front board needs replacing? Thanks Ori
Some times I feel like a broken record, but inside your machine it should have a tech sheet. If you find it read it, cause it will help locate the problem. But you didn't really say exactly what you machine is not doing. Is the drum turning, just not getting hot? Drum is not starting at all. Does the drum turn when you turn it by hand? My bet it's your door switch, and or you electric outlet has a problem.
Jun 21, 2015 • AEG Dryers
I have a AEG LAVATHERM 59800 DRYER AND IT IS NOT GETTING HOT NOW AND I HAVE CLEANED THE VENTS BUT STILL THE SAME? ALSO WHEN IT REACHES 0 AFTER A CYCLE IT IS NOT SHUTTING DOWN OFF? CAN YOU HELP?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 19, 2015 • AEG Dryers
E60 code on Aeg lavertherm dryer understand it us
Yes the NTC or thermal cutoff failure can cause E60 error.
It may look something like this.
AEG Thermostat Thermal Limiter
For diagrams of your dryer refer this site.
AEG LAVATHERM 60750225500 Tumble Dryer Thermostat Spares Parts
Sep 20, 2014 • Dryers
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
2helpful
Squealing noise on start up drying still works
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
Top AEG Dryers Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you an AEG Dryer Expert? Answer questions, earn points and help others
