Hello avid.....
If there is no power to the receptacles: 1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator. 2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual on page 1 - TO TEST A GFCI: Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle. The RESET button (B) will pop out. Power is now off at the receptacle. If the RESET button does not pop out, the GFCI is not working. Do not run generator until the problem can be corrected. To restore power to receptacle, push the RESET button in. If the RESET button pops out during operation, 3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that requires 240 Volts). 4. Turn the idle control switch off. 5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are securely connected to the receptacles. 6. Turn the circuit breaker(s) on. 7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
stop the generator and check the generator and equipment for defects.
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
Have you checked to see if the circuit breaker has tripped?
HI I AM A REPAIR SHOP I DID SOME TROUBLE SHOOTING BUT I NEED WIRE DIAGRAM
I AM HOPING SOME ONE HAS ONE SO I AM LOOKING OTHER PLACES AS WELL COME MONDAY IF I DO NOT GET ONE I WILL CALL DEWALT FOR MORE INFO
THANK YOU FOR YOUR IN PUT
NED WIRING DIAGRAM SO I CAN TROUBLESHOOT IT
DEWALT DG6300B
I NEED A WIRING DIAGRAM I DO NOT PLAN ON TAKING IT TO SERVE CENTER DO YOU KNOW WARE TO FIND ONE I HAVE NO POWER COMING TO THE PENAL AT ALL
SAME THING
