Describe your AEG Lavamat 60210 Front Load Washer Problem we have intermittent problem with E5O after 2-3 washing cycle we have replaced the motor ( renew one) and the problem remain
Intervention of motor overheating safety cut-out. Possible fault Motor faulty; Intervention of motor overheating cutout; Wiring faulty; Electronic board faulty. Machine Status/Action Power to the heater unit and reversal of the direction of rotation are interrupted. If the problem does not re-occur, the alarm is memorized and the cycle continues. If the fault persists after several attempts to supply power (about 35 min.), alarm E51 is generated.
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
