Whenever I turn the DSC-W70 on it displays a black screen and the word "Access." At the same time the lens extends and retracts, however unlike some of the other problems people are having, the lens is not getting stuck. Also I also notice a faint clicking/buzzing sound from within the camera when the lens is still and not retracting/extending. After about 10 seconds it begins to beep and displays the message "Turn the power off and on again." I am able to view previously taken photo's and the menu from the viewing screen. This has allowed me to initialize the settings but this has not worked. Any Ideas on what to do?
Thank you :-)
DSC Ni
access message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
apparently i have some bad news , its the lense which is misaligned or broken in terms of gears, the thing to do turn on the camera and make sure that lens is out and then LIGHTLY tapp on the lens the direction of which you feel that the lens is not equal legnth to the outer ring > place that looks uneven
black screen with the word acess. then that faint clicking nosie. followed by the turn camera off sign. that is exactly what mine is doing
i brought an extra battery thinking it could be a bad battery but it is not the camara has put a message to ACCESS something and the screen is black and now the camara doesnt want to turn or off....what should i do
