SOURCE: Door interlock flashing
Same issue with loose solder joint on the relays inside CCU (computer control unit)
the same bad CCU is used by several manufactures.
you have to open the CCU and re-solder the the relays to the board. they have microcracks around the legs.
you will get the door lock issue randomly.
to prove the issue open the top access panel .and pull up on the center black plastic connector and the issue will go away.
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
SOURCE: got a hotpoint washing machine aquarius WT540
If the catch is broken you are going to need to get at it from inside to release it.
This is usually best done by taking the top or back off and reaching in to release the lock.
Make sure you disconnect the electricty and water before trying this.
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: HOTPOINT AQUARIUS WF250
washmashine hotpoint wf 321 its start working prewash and not change the program ror wash and spinning
when start some smell come out i check inside and i find interlock is burn
i want ask if i change interlock i sort the problem? please let m e sort that problem thank you
[email protected]
