Hi
To resolve the issue you’ll need to then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. In case you need more information then please post back with the make and model number. Hope this helps...
Daniel
