When the engine and carb were new, the factory settings were 1 1/4 turns out. As fuel deposits form and things wear, it is normal to need occasional adjustment. If the adjustments need to go more than 2 1/2 turns out, or if the adjustments seem to need constant change, then the carb needs to be overhauled. Here in the USA, many areas use gas that is 10% alcohol. The alcohol effects the soft parts in the carb and will often cause hardening of the diaphragm. If/when you overhaul the carb, also replace the fuel lines and tank grommet.
Good Luck!
Testimonial: "Thank-You ... very helpful !"
