1. Park vehicle on level ground.
2. Remove battery from vehicle.
3. Remove air cleaner outlet hose, engine under cover ( right side ) and exhaust pipe # 2 .
4. Disconnect " B " terminal wire and coupler from the Alternator ( Generator ) .
5. remove Alternator ( Generator ) belt.
6. Remove Alternator ( Generator ) cover.
7. Remove Alternator ( Generator ) bracket mounting bolts.
8. Remove Alternator ( Generator ).
Installation : Reverse dismounting procedure.
Replace Seal Ring between exhaust pipe # 1 and exhaust pipe # 2.
Torque exhaust bolts to : 43 N-m ( 4.3 kg-m,31.5 lb-ft )
Replace cable straps / defective parts as necessary.
Reinstall battery.
