Luggage & Travel Logo
Posted on Aug 05, 2010
Digit problem and solution? - Brookstone Luggage & Travel
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 25, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1739
Points
8
A number is 3 more than 4 the sum of its digits. If the digits are interchanged, the resulting number is 9 more than the given number. Find the number.
Anonymous
Level 1:
New Friend:
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1739
Points
5
A number is 3 more than 4 times the sum digits. If the digits are interchanged, the resulting number is 9more than the given number. Find the number
Anonymous
Level 1:
New Friend:
  • Posted on Dec 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1739
Points
Let x= original number 10t + u =3 +4( t + u)10u + t = 9 + 10t + u
10t + u= 3 + 4t + 4u ----------> 10t-4t + u -4u = 3---------->6t -3u =310u- u + t - 10t = 9 ----------> 9u - 9t =9
[6t -3u =3] 3 -----> 18t-9u = 9
+-9t + 9u =9
9t=18t= 2
substituting 2 as tens digit:10(2) + u =3 +4( 2 + u)20 + u = 3 + 8 + 4uu - 4u= 11-20-3u= -9u= 3
the number is 23.
I have a digital wrist watch and I can not set it up.
hi Claude.
Press and hold the "Adjust" button to until the "Time" digits begin to flash. Use the "Start/Stop" and "Split/Reset" buttons to set your digital watch to the correct hour and minute increments. Press "Mode" to display the "Date" setting screen.31 Mar 2015
Digital Watch Instructions ' Techwalla.com
https://www.techwalla.com/articles/digital-watch-instructions
How do u set a digital watch?In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.4 Button Digital Watch - Dakota Watchhttps://www.dakotawatch.com/PDF_FILES/Digital.pdfSearch for: How do u set a digital watch?
how to set digital wrist watch Google Search
Nov 27, 2017 • Watches
tip
How to improve picture quality of Digital Camera
Slow down the shutter speed of your digital camera. Whenever you must take a photo in a low light environment decrease your shutter speed. It is virtually impossible to take a blurry digital photo with a an extremely slow shutter speed. Even if your digital camera has an automatic or semi-automatic mode, slowing down the shutter speed will still produce a better digital photo. <br /> Wait until your digital camera is completely focused. Most digital cameras will notify you that they are focus ready by a blinking light, on screen indicator or a noise. Confirm that your digital camera has locked onto your desired target before pressing the shutter release button. Some digital cameras may have trouble focusing on subjects easily. If this happens use an auto focus mode to produce a better digital photo. <br /> Prevent your digital camera from shaking. Shaky hands or sudden movement will definitely produce a blurry digital photo. When holding your digital camera, make sure the viewfinder is firmly pressed against your face before snapping a digital photo. If you do not have image stabilization on your digital camera, then think about investing in a tripod. This will allow you to steady your digital camera for the perfect shot. <br /> Make sure the digital image is definitely a blurry one and not just a soft image. On many occasions soft images are mistaken for blurry ones. Soft images occur often with digital cameras. When printing these images, the softness rarely shows through. You will be able to easily edit these photos by sharpening the details for a better printing experience. <br /> Take your time. Instead of rushing to take a digital photo, set aside enough time to shoot your image. Hurrying up will not produce an excellent digital photo. You don't need to be overwhelmingly slow when taking the photo, but try your best not to take a hasty one.
on Dec 31, 2010 • Cameras
3answers
Ineed a code for tv converter box,What would the code be for a tv converter box ?
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
How do i round numbers to the nearest thousand?
Identify the digit that sits at the THOUSAND position.
All the digits at the right of it will be replaced by zeros.
The THOUSAND digit itself may be left unchanged or increased by 1, depending on the digit that sat at the HUNDRED position.
If the digit at the HUNDRED position is 0, 1,2,3,4 the digit at the THOUSAND position is left unchanged.
However, if the digit at the HUNDRED position is 5,6,7,8, or 9, increase the old value of the digit at the THOUSAND position by 1.
Examples
5768 469 becomes 5768 000
5768 743 becomes 5769 000
5769 469 becomes 5769 000
5769 743 becomes 576 (9+1) 000 Patience
9+1=10, so you must increase the 10-THOUSAND digit by 1
Thus 5769 743 becomes 5770 000
If any other digit to the left of the THOUSAND digit reaches the value 10 (no digit), then increase by 1 the digit at the left of it.
Bike will not turn over, security icon flashes alone with the turn signals. Battery test OK.
Have you used the new PIN to manually disable the security system?
Do not turn handlebars, straddle seat or lift motorcycle off the jiffy stand. During a PIN disarm, if the security system detects motorcycle motion the system will activate.
Turn ignition to IGN.
If armed, the odometer window display will read: ENTER PIN and the security lamp will be flashing at a fast rate. The headlight will not be on.
Press and release the left turn signal switch.
In the odometer window, a flashing 1 will appear.
Increment the digit by tapping the left turn signal until the odometer window displays the first digit of the PIN.
The first digit in the odometer will be the first digit in the PIN.
Press right turn switch 1 time.
The first digit is stored and the next digit will flash.
Increment the second digit using the left turn switch until the digit reaches the second digit of the PIN.
The second digit in the odometer will be the second digit in the PIN.
The second digit is stored and the next dash will flash.
Increment the third digit using the left turn switch until it reaches the third digit of the PIN.
The third digit in the odometer will be the third digit in the PIN.
The third digit is stored and the next dash will flash.
Increment the fourth digit using the left turn switch until it reaches the fourth digit of the PIN.
The fourth digit in the odometer will be the fourth digit in the PIN.
The fourth digit is stored and the next dash will flash.
Increment the fifth digit using the left turn switch until it reaches the fifth digit of the PIN.
The fifth digit in the odometer will be the fifth digit in the PIN.
The fifth digit is stored. The security system indicator lamp stops blinking.
Smart Security System is disarmed.
If a mistake is made while entering PIN, turn the ignition Switch to OFF before entering the last digit and then start the procedure from the beginning.
If the procedure fails to disarm the security system, wait two minutes before attempting another PIN disarm.
The security system will remain disarmed until the ignition is turned to OFF.
2answers
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Top Brookstone Luggage & Travel Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Brookstone Luggage and Travel Expert? Answer questions, earn points and help others
