I have a G E top loading washing machine model # gsls1100d an for the last few months the lint traps in both sides of the machine and on the grey band below the top of the machine have been collecting the laundry powder that was suppose to have dissolved through the washing cycle. Your company suggested I use Sunlight Washing Laundry soap now I am using Purex liquid soap but I still get some residue of soap left over after the cycle is done. What could be the problem?
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
If the model number is true in the blue this a top load washer there is no lint trap lint collects on the protrusions on the outer side of the basket and is washed away during the rinse drain spin cycle
There is no lint trap on these washers. The manufacturers are depending on the dryer to remove 80% of the lint. The only solution they give is when sorting the clothes separate the lint givers from the lint takers. Hope this helps
Their is no lint trap on that washer, GE washers are built to be sold at the lower end of the price scale and dont include features found on upper end appliances
Have you ever cleaned the lint trap? many people do not realize that washing machines have lint traps too. It is usually located under the fabric softener cup in the agitator -- not sure on yours without model number. It has a lot of tiny holes in it that clog fairly easily. One trick to clean it is to put it down in the drum where the wash goes and run a wash cycle, but you may have to do a bit by hand as well. Hope this helps.
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads. Eric
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Most washers don't have lint traps, the dryers are expected to. In your type of top loader some simple traps would be located in the top cap of the agitator. They should be cleaned each load, but they only stop the bigger pieces.
