Sony Cyber-Shot DSC-T3 Digital Camera Logo
Posted on Jul 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony DSCT33 flash will not work on any settings
Anonymous
Level 2:
Genius:
  • Expert 1,040 Answers
  • Posted on Jul 20, 2010
Anonymous
Expert
Level 2:
Genius:
Answers
1040
Questions
6
Helped
289949
Points
144
You have to get it serviced coz, there are chances that the flash bulb has gone or loose connection...
Thanks....
How do I fix the flash on my Sony A390?
Sony eSupport - DSLR-A390 - Support
https://esupport.sony.com/.../model-find.pl?...DSLRA3...
Sony CorporationModel # DSLR-A390 ' change model. ... not go away · The background of a picture is dark and underexposed when using a flash. ... My A7R II is dead... or is it?
A390 flash not working. - Sony's Community Site
https://community.sony.com/t5/Alpha-SLT.../A390-flash-not.../437652
Sep 2, 2014 - My sony A390 onboard flash is not working not matter what setting I use. what can be done to fix this?
B
1helpful
How do you turn the flash on in a sony cyber-shot camera?
The flash mode can be turned on by pressing the UP ARROW button dontinuously for the desired settings. Set it to Forced Flash to turn on the Flash for all the time.
The flash mode will not work when the REC Mode is set to Burst or Multi Burst. It will not work when the Scene selection modes like Candle Mode and Twilight mode is selected. Flash will not work in MOVIE mode also.
2answers
K800i came flash not working
check your camera settings and flash settings. i it doesnt then go to nearby ressel and get the work done. I advice go to sony ericsson service centre .
2answers
Sony w70 camera not working,flash error showing thatE:91:0
    The flash unit assy need to be replaced.Also E:91:0 is for flash unit purpose which means that flash unit get malfunctioning.
For this you have to contact any nearest sony service centre.
Thanks for using fixya, and dont forget to rate.
2answers
My DSC-T100 won't allow any changes to the flash setting.
The flash settings on the Sony Cyber-shot DSC-T100 are Auto, Forced Flash, Slow Syncro and No Flash, if it is not giving you a flash and wont allow you to change the setting you might have to talk to sony or the store you bought the camera from. One long shot would be that depending on what other features you are using on the camera, i could be set up to not allow you to change the flash settings in that "mode". Sorry if this is useless, but good luck and if all else fails use sony support! :)
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7
stupid hyperlink not working :(
Hello, I have a 5.1 MP DSCT33 SONY CYBERSHOT and I have a 512 MB Memory Stick, but for some reason after 12 photo's it states there is no memeory space???? Was fine a montha ago, then suddenely...
perhaps that previous photo's have not been erased or cut and paste to your hard drive , put the memory stick in a cardreader and explore it see how many photo's are on the stick . i don't know th file size of your camera but gues that that is the question (it should be able to store 12 pictures in highest resolution a a 32 mb memory stick.
Jun 01, 2008 • Cameras
9helpful
6answers
Flash not working
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
Sony cybershot dsct33
1st u need to go to sony .com download the software for you model camera from ther driver download section ok once u do that use usb cord turn power on cam sony software open it will pop right in or go to my computer u will see sony cam icon clik in nit drag pics to desktop
Jan 31, 2008 • Cameras
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
