Follow the procedures given below to have a perfect fix for your problem.
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Thank you !!
It's a flash error. Most likely the flash fuse is blown. Has to be replaced (soldered as it's a SMD fuse). Sorry, but you will have to give it to a camera technician as it's a bit complicated and requires some experience.
I have repaired lots of these - I have worked in a Sony service center.
Tom
I tried that multiple times and it has not changed the error message. Any other thoughts?
Thanks
SOURCE: E:91:01 Error
E:91:01 is error code related to Flash Circuit abnormality. It requires qaulified technician to fix and such person would be available at nearest Sony repair shop.
SOURCE: e:91:01
hi there
you can try doing this and it should work and solve the problem for you
SOURCE: E:91:01 flashing
i also have E:91:01 flashing on my camera and when i take a picture it does not flash even when my camera is on flash
SOURCE: Sony DSC-W50 Flash Error code-E:91:01
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
