Good evening;
I want known if the TI 89 Titanium is capable to display the standard error fo slope when I perform a linear regresion. Any information that your can bring me will be accept.
THANKS
[email protected]
SOURCE: TI 89: Argument Error.
I reset the calculator and it did its job- though a solution would be handy.
SOURCE: TI-89 Won't Turn On
Please don't get your hopes up, but perhaps something in the following few suggestions will work:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
To reinstall the Calculator's operating system, take a look at the following TI site.
On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetNumber=12089
I would hunt around on the TI knowledge base to see if there are some more useful suggestions if nothing above works. If I find any more info that could be useful I will post it.
SOURCE: how do you restore a TI-89 Titanium clac
Perhaps one of the following sources will be helpful:
To reset the TI-89 family, TI-92 family and Voyage 200 graphing calculators, press [2nd] [6] (reads MEM over the key). The [F1] menu appears and contains the following options:
For example, I think you will want to follow the last step above... which would be to press [2nd] [6] [F1] [1] [1] [ENTER] [ENTER].
Also, if you are looking to clear all the RAM in another way I would take a look at the guidebook, which is downloadable from the following site in PDF format.
http://education.ti.com/downloads/guidebooks/graphing/89ti/TI89TitaniumGuidebook_Part2_EN.pdf
Take a look at page 951 and 952 for another way to clear the RAM
SOURCE: where is 1/x on ti-89 titanium
There is not such button but 1/x=x^-1 so just take it in power -1 it is the same.
Rate me please, thanks.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
