I borrowed my friends pressure washer and it was working when i had it but she says its not now, could u tell me what u think it could be please. Could it be a motor problem and if so can u explain how a motor would go without me touching it as i dont like the idea im being acussed of breaking it when it was working when i gave it back
I have a question because I am using a gas pressure washer more long time but I want to use electric pressure washer so please tell me something about the best electric pressure washer. http://car-gears.com/
When you start your engine open wand trigger this will probably allow you to get the engine warmed up and I think it'll work for you it used to work for us .
Most of the time it is the GFCI on the end of the plug that goes bad. If it were me I would cut off the GFCI and wire in a standard 120v plug. If it still doesn't work after that then there is a good chance that something electric internally has gone wrong which isn't going to be worth repairing.
if the water is in anyway impeded, like kink in hose the unit turns off and goes into protection mode. That it it shuts down for a pewriod of time depending on how hot it may have got.
When its rested try it again ensuring you definitely have water flow.If the solenoid has failed it costs about !60-200 to fix as they replace all seals regardless
hi. you will need to go inside the machine to have a look, but it might just be a micro switch on the bypass valve stuck.
you can not miss it, there is a wire going to it, just unclip and check with a meter when pressing the little switch in and out.
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back. If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
