My Bosch Nexxt 100 Series washer beeps three times and flashes the spin, wash and finished lights simultaneously, but won't proceed with any cycle chosen. I had started a new load and the machine stated as normal (filling with water and drum rotating), but then I paused it to add a few more items (which I have done numerous times before). When I pressed start/pause again to restart the machine, the blinking and beeping behavior began. I tried unplugging the machine as a reset with no luck.
If you are the fix-it-yourself type you can take the screws out of the front panel and top panel ( if the door is locked there is a green cord hanging inside the round port on the bottom of the front panel, find it and pull it to open the door) then take the two screws out that hold the switch and unplug the 3 modular plugs on the switch.
The switch comes apart by carefully un-clipping the brown clips around its edge. Take note of the assembly inside so you can put it back together properly. The little armature that goes through the magneto sometimes slips out of the groove where it ends with a small flat head. once everything is in place clip the switch back together and install the plugs and the switch.Replace the panels and screws and you should be back to normal. Do this if other remedies fail.
C.Dominici
SOURCE: beeping
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
SOURCE: Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
SOURCE: Bosch Nexxt premium front load washing machine
First try unplugging it and let it sit for 20 minutes.
Plug it back in and read what it is displaying then.
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
SOURCE: Bosch Nexxt Premium WFMC6400UC does not start
A faulty module or timer/control panel. Unless you are getting some form of error code in the way of flashing lights or otherwise. In which case refer to manual. Good luck.
