Step1:
First, unscrew the 7 screws holding on the door panel
Step2:
Next you carefully pry off the tweeter cover that is where the mirror is.Lift the panel up and off of the door . Undo all of the wiring connections except for the window controller.
Step3:
Open the 2 black rubber view ports (Circled in Yellow) and roll the window up or down until you see the 10mm bolts that hold the window in place.
Step4:
Loosen, but don’t remove these bolts. Slide the window up, and tape it up, or remove the window and set aside. Next, unplug the door lock plug and move the door panel out of the way.Unscrew the gold 10mm bolts that hold on the metal inner door panel . Also remove the Phillips screw that holds the inner door handle on
Step5:
Unscrew the small bolt that holds on the lock cylinder that is behind the quarter-sized black cap on the side of the door. Be careful with that little bolt or it will fall into never land .Pull the lock cylinder out and set aside.
Step6:
Now grasp the door handle, and with your free hand smack your hand holding the handle towards the back of the car. This will release the door handle.Under the door handle is a Phillips screw. Loosen this screw a few turns but don’t remove.
Step7:
Now undo the 3 black star shaped screws on the door lock.You can now wiggle the inside of the door handle until it comes free. See the tabs that hold it onto the door . When you go to put it back on be sure the tabs get back in the right place.Pull the whole inner door panel and lock mechanism free by wiggling it out of where it sits.
Step8:
Now you can undo the 3 cables; 1 from the outer door handle yellow mechanism, 1 from the inner door handle mechanism, and 1 from the inner door lock lever.Put on the new lock and put it all back together.
Be sure to test it as you go. I had to turn the lock cable to the inner door lock lever 180 degrees because it was not unlocking properly when I put it back together the first time.
A couple of other notes, there are 2 pieces of plastic that are for the robots to use when putting the door together for the first time. one is a 3 pronged white plastic thing riveted to the inside of the metal door panel. The other is a white plastic thing covering the lock mechanism. You can cut off the fingers and throw the plastic cover away they are both
useless and in the way.When you put it all back together, just go in the opposite order of disassembly. It is a little tricky to get the yellow plastic outer door handle holder into place. Be sure that the little tabs grab the metal of the door or things will not fit together properly.Be sure to test the power window after you put the window back in place. Do not overtighten the bolts on the window, it is glass…..
