My Whirlpool front load washer is displaying error code HF and doesn't want to finsh cycle. Can anyone help me with this?
Thank you!
After washer is finished a small stream of water will fill up washer after setting over night. water is comeing out of the water port hole when filling up for a load.
Http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Bears repeating
F dl refers to a bad door lock. do you hear a faint clicking noise when you try start the machine and after maybe 30 secs of clicking the" fdl "comes up???or perhaps the door makes the noise to lock but never does lock,in which case sounds like a bad latch assy.. although the fault for the door latch it could also be the CCU not energizing the door lock. try taking off the top of the unit by removing the 3 screws along the back of the top assy (they are torx 20 screws) form there youll see the main control board mounted to rear wall and if you look straight down the right front side youll see the wiring for the door lock itself. disconnect power to unit!!!!! first unplug and replug all the wire harness on the door latch and then also the pink wires on the module itself, maybe just a loose connection. try it now see what happens
What does it mean when are washer flashes H F and beeps..THANKS RON
