Magellan Maestro 3250 GPS Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost operating manual, and need new one. Can I
Lost operating manual for a Magellan Maestro 3210, and need new one. Can I download this manual from a web site.
Anonymous
Level 3:
President:
  • Master 1,111 Answers
  • Posted on Mar 25, 2010
Anonymous
Master
Level 3:
President:
Answers
1111
Questions
6
Helped
381002
Points
3221
tip
Could not get this to work with a Magellan Maestro 3210 where the 2008-09 map...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
How can I update my Magellan Maestro 3210?
  • Hi if you want to update the firmware just login to the website of Magellan and make sure that the GPS must connected when doing the update.
  • For the map update call the customer hotline and check if you can get a free map update or if they have discounts for map update.
  • If you have followup questions don't hesitate to reply to this solution.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
My Magellan Maestro 3210 constantly says low battery while on trip and shutoff, I have it plugged into the astray why would the battery be low, how do I get it off battery power setting, or why is it doing...
Usually when you see low battery like that it means the battery itself needs to be replaced at it can't hold a charge or enough of a charge to be usefull. If you unit is over 18-24 months old then th e battery is most likely the problem. This will happen even if you have always used external power as the battery doesn;t get properlly cycled enough.
It is possible that it is the power source you are using is too low but sounds more like the battery is the problem.
If you have warrenty the battery should be replaced by Magellan. If not a replacement battery is about $30 and is something you may be able to do. You need to remove the back cover and unplug the old battery and plug in the new one and put it all back together.
Here is one link for a battery but there are other just search for Maestro 3210 battery with google or bing and you should find a few places that offer them.
http://www.batterymart.com/c-magellan-maestro-3220-gps.html
1helpful
I need a free magellan maestro 3200 manual.
Hello therre:
Please follow this link to the manual and you can download it free it is in pdf format ok
Magellan Maestro 3200 Manuals, Support and Troubleshooting - GPS Free download of Magellan Maestro 3200 User Manual. Troubleshooting help from experts and users. Ask our large community for support.
www.retrevo.com/support/Magellan-3200-GPS-manual/.../2/ - Cached - Similar
How can i update my magellan maestro 3210 without usb cable
i would go www.magellangps.com and download them from the website directly to your computer. Then your gps should have a memory card reader of some sort. You can take your memory card and the updates you downloaded and then you load the updates from the memory card. .
2helpful
1helpful
How do l update my maestro 3210
you will have to go to magellan.com & order the 2008/2009 map update. it costs a hundred bucks unless you are a caa member, then they knock off 25% or so. You can't burn a copy because they need a special code to make sure you bought it legally. Pretty smart. I just got mine & am trying to get it loaded now.
Good luck
Alex
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
