Timex 1440 Prizefighter 53032 Sports Wristwatch Logo
Anonymous Posted on Mar 09, 2008
Timex 1440 Sports Radio Time and CDT Instaructions
How do I set the Daylight Savings Time feature on my Timex Sports Radio Controlled watch ?
  • Anonymous Mar 09, 2008
    I did get a manual from Timex but it has been misplaced. Where can I get a manual for the time 1440 sports radio controlled watch.
    The manual in ** longer available from teh Timex website.
    I tried the link with ** luck. This is an older 1440 that has a specific step to use CDT. It does net set automatically.
    I\'ll keep looking. Thanks
Anonymous
Level 3:
Genius:
  • Master 3,587 Answers
  • Posted on Mar 09, 2008
Anonymous
Master
Level 3:
Genius:
Answers
3587
Questions
29
Helped
1147136
Points
9064
Just change the time from the menu...unless we're missing something here
  • 2 more comments
    you get a manual with that timex?
    well..there will be some in the blogosphere..let me see what this wizard can find.
    thanks for using fixya
    maybe you got lucky today..check out this link
    thanks for using fixya and maybe you'll find it..remember to close this one out too
Timex radio controlled watch i need operation guide
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
How do I change to time and date on my radio controlled timex 1440 sports watch. (it has three buttons on each side)
manual download"
How to set my timex watch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
7helpful
How do i set the time on a timex 1440 sports
Here you go old chap:
http://assets.timex.com/manuals/
Cheers.
3helpful
Timex ironman triathlon - need directions to adjust time for day
Follow this link and download usars manual for your watch:
http://assets.timex.com/manuals/?timexBrand=core
Use ZOOM tool as the writings are tiny.
Do not forget to rate, please.
4helpful
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Cannot changer from 24 hour to 12 hour
You could change between 12 and 24 hour by pressing the "Mode" button and the "Receive/Start/Stop" button at the same time. I still cannot figure out how to reset for Daylight Savings Time, though.
Timex T5E881
You have to get in the right time zone, that’s why you are an hour off (and this may also occur if you are in an area that switches between daylight savings time each spring and fall).
Press mode until ZO appears on the watch face.
Press and hold ADJ. Time zone will begin to flash.
Select start/stop or adjust to get to the right time zone P, C, M, E (pacific, eastern, Mountain, central)
If desired , press mode to select DST (daylight savings time) and press start/stop or adjust to turn it on or off.
Press adjust when done.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
