mine is stuck on e20. i did restart the programme and washed again but the e20 error came up again.
I am not sure how to blow down the waste pipe - wont all the water come gushing out if i remove the waste pipe? mine is stuck on e20. i did restart the programme and washed again but the e20 error came up again.
You can't post conmments that contain an email address.
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
E20 means you have a drain problem. Check the drain filter on your machine to make sure it isn't blocked by fluff/coins/etc. Should work again unless you have a bust pump (which I had).
If machine is full of water, do an emergency drain through the little pipe on the bottom front. Good luck.
E20 is a drain problem. Clean out the drain filter, normally found bottom of machine. Do emergency drain first or you will flood the room if there is water sitting in drum. Hopefully you just have a blocked filter or pipe, otherwise you may have to replace pump if it has failed.
The E20 error means that the thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing.
Check the thermistor and associated wiiring for correct resistance and operation and replace if required.
stuck displaying e20
