Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
Posted on Nov 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toro leaf blower Model 51591 from 2003 has started
Electric Toro leaf blower Model 51591 from 2003 has started making loud screeching sound when operated, both with or without the impeller. Sound began after vacuuming a wood chip which broke part of a fin off the impeller. Does it sound like a motor problem which would be more economical to remedy by buying a whole new unit rather than repairing?
  • 0154 Nov 13, 2009
    As I indicated originally, I had also tried the unit without the impeller and it continued to make the same screeching noise.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1246
Points
6
Sounds like the brushes are worn out.
Roland W VanLue
Level 3:
  • Master 486 Answers
  • Posted on Nov 13, 2009
Roland W VanLue
Master
Level 3:
Answers
486
Questions
0
Helped
315026
Points
1454
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
2answers
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Motor won't turn on
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
1helpful
Blower does not turn on
Apr 03, 2014 • Toro Garden
Snow blower shorted out
1helpful
Motor was losing power and burning
3answers
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
2answers
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
1helpful
2answers
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
