Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
SOURCE: it tell me that i need the puk code to unblocked
You can get the PUK code from the Service Provider........
SOURCE: pin is blocked need puk
When a PIN code is entered wrongly three times, the phone line will be blocked. Irrespective of the owner, it is assumed that you are not the owner of the phone line when you enter your pin wrongly.
The blocked line at this point can still be unblocked and this is where the PUK code comes in. Once you enter the PUK code, your PIN code will be reset. You can then create a ne PIN code.
To get your PUK code, if your phone is using a SIM Card, Check the SIM card Pack and you will see your PUK code there. But if you don't have a SIM card pack, you can get the PUK code from your service provider.
Call the customer care line of your service provider using another phone, request for your PUK code and it will be given to you. Note that your service provider will ask you some few questions about your line in order to be sure you are the real owner.
Note that your service provider alone is the only one that can give you your PUK code because it's only your service provider that has it.
Good luck.
SOURCE: PUK Code
the PUK code is printed on the plastic card where the sim card was in. if you lost it, try contacting your provider.
hope it helps
