Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Posted on Nov 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore HE3 washer started knocking and shaking during spin.
My 5 year old Kenmore HE3 washer started seriously knocking and shaking during final spin. I stopped it immediately, but now it won't spin. It just turns real slow and that's it. It's level and steady when I try to move it. No codes. I think the stainless steel tub is looser than it used to be with more movement front to back.
Bill Boyd
Level 3:
Top Expert:
  • Kenmore Master 53,816 Answers
  • Posted on Nov 20, 2017
Bill Boyd
Kenmore Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950053
Points
172802
Indicates that the tub support rods have failed at the air dampners
the fix is new rods from the service agent spares and a re levelling if the tub ,not the machine
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 28, 2007
SOURCE: washing machine
the u-joint balancer kit needs to be replaced. it located under the wash plate where your clothes. its not the stainless steel. you might want to do a search to see if your model falls under the class action on this washer before you repair it
Anonymous
  • 125 Answers
  • Posted on Jan 31, 2008
SOURCE: Frigidaire Washer - Loose Inner Tub
the inner drum is most likely broken. go to sears.com select appliances then select parts enter model number and you can get a blow up. Hope this helps.
Anonymous
  • Posted on Feb 17, 2008
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Anonymous
  • 324 Answers
  • Posted on Dec 30, 2008
SOURCE: Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Anonymous
  • Posted on Feb 04, 2009
SOURCE: Kenmore Front loader Washer Problems
u need to remove the shipping bolts, found in the back of the washer, 4 long bolts used to hold the drum in place while transporting. we had same prob
How to run diagnostic on Kenmore elite smartwash quiet pak 9 HE4t washer? Model#110.45087401
Diagnostic mode for Kenmore Elite He3t model 110 42926 ...
iFixit https://www.ifixit.com > Answers > View > Diagnostic...
Apr 8, 2016 - With the washer empty, close the door. · Push "control/on" or "Start" · Select "Drain/Spin" · Select "No Spin" by pressing SPIN SPEED touchpad.
3 answers · 2 votes: I believe this is very similar to the model I have. Here is what I did to run a diagnostic. ...
F11 error code during Diagnostic test? - Kenmore ...
1 answer
Jan 18, 2016
SOLVED: F11 code error on Kenmore HE3 - iFixit
Mar 3, 2011
SOLVED: f h error code - Kenmore Elite HE3 ...
Feb 21, 2012
It seems like the washer has no power - Kenmore Elite ...
Nov 2, 2017
More results from www.ifixit.com
Diagnostic Test; Starting The Test Mode; Test Program ...
ManualsLib https://www.manualslib.com > ... > User manual
Close the door. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button five (5) times. Push Prewash Option button four (4)times within ...
1helpful
Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Load noise during spin cycle also metal wire sticking out of drum inside washer. This is a Kenmore elite he3 5 years old
i think it might be fixable but u should go to O' Riley's Auto Parts and ask someone there.
1helpful
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Kenmore He3 sometimes sound like a jackhammer in spin cycle
Have you tried less items? It could be the load is not balanced. Try placing items around the tub evenly. This unit is about 12 yrs old so it could be a bearing.
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Kenmore HE3
usually the only reason for this is out of level these machines spin very fast. if you have it on carpet it will also shake quite a bit it is best to cut a piece of plywood for the washer to sit on so it is easier to level up
WASHER SOUNDS LIKE AN AIRPLANE TAKING OFF DURING SPINE CYCLE
Most likely a failed "spinner" assy. The roaring that you hear is the bearing telling you it's had enough and has gone on strike.
MAJOR job! If it's over 5 years old, I recommend calling a professional and get quotes. Then decide what you want to do.
If it's less than 5 years old, it should be under warranty. Contact Sears. Tell them you have a failed spinner and tub bearing assy. and have them do the repair.
*Just a quick note. You should use only HE detergent in these machines.
Tracy
1helpful
Alexander
vince
