AEG Lavamat 72640 Front Load Washer Logo
S Moore Posted on Oct 19, 2009
AEG 72640 stopping mid-cycle no error code showing
My aeg oko lavamat 72640 update keeps stopping in the middle of programmes. Sometimes the stop/pause button flashes but pressing it doesn't restart the programme. At other times the indicator shows a large amount of time to go but the programme can't be restarted. It all started when I tried to do a 60 degree cotton wash. I am forced to run the "drain" programme then the "rinse" and try again with different programmes. Intermittently, I am managing to do a 40 degree easycare wash but not every time. Help!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4232
Points
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
  • Anonymous May 11, 2010
    Problem is that the circuit board for the motor control is broken. It needs to be replaced. It's fairly easy to do but the new circuit board is not cheep.
Anonymous
Level 1:
New Friend:
  • Posted on May 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4232
Points
HAVING THE SAME PROBLEM WITH A L 64851
  • Michael Smith
    Michael Smith May 20, 2014
    I have a 3 year old aeg lavamat 64854L. It stopped mid cycle and will not pump out the remaining water. I played around many times but could not get the machine to work, it just made a noise like it was trying to pump. I emptied the remaining water using the little hose under the flap on the bottom right. Still won't work. Had repairperson come to house, He checked it out and said "Everything is fine, no problems. OK, I was happy about not having a big repair expense but will it happen again or? Wait and see. My biggest problem with this machine is the dial keeps sticking, the buttons as well. A bad design?
My AEG OKO LAVAMAT 72640 keeps stopping mid cycle and flashing error cod E10 what can I do?
The water Supply
1. First, check that the tap is not accidentally turned off.
2. Check that the gray water inlet hose is not squashed or kinked lies.
3. It is also possible that the filter is clogged in the supply hose. Close the tap and disconnect the hose. Here is some pressure on it, so keep a towel handy. Check the filter that output waterklraan, and clean it if necessary.
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
2answers
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
10helpful
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
8helpful
Oko lavamat 74640 update showing error E20 what does this mean?
its a draining error, check sump, pump and drain hose for blockage failing that it needs a new pump.
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
2helpful
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
