Nokia 8600 Luna Cellular Phone Logo
dale crockett Posted on Oct 15, 2009
Cant charge nokia 8600, charging point connection broken,can i purchase new point and how do i replace
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Feb 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
4894
Points
82
Sanyo zio scp-8600 will not charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
It wont charge
it could be three issues. 1.) The battery is dead. 2.) The cable charger is a cut wire or is faulty 3.) The charging port on your phone is broken and not delivering power to the phone. If it is the battery or cable, you can purchase new ones from many online sites, such as Amazon. If the charging port on the phone is broken, you must call your cell phone provider and let them now. This way they can send you a replacement as soon as possible!
Nokia 8600 luna charging port broken
you can try to charge the battery directly, introduction a minimal current to the +ve and -ve terminals of the battery using two live wires
2helpful
2answers
3315 not charging
First Option:
Secend Option:
Thanks
Ok so my sidekick 09 usb connection its ok wen i charge it, it charge **** when i plug itt into ma computer nothing happen. The usb connection its broken i guess
You are probably right. If you have been able to charge your phone before via the micro USB connection, the most logical answer would be that there is something wrong in the connection. Try a new micro usb or go the page where Nokia
supports it´s customrs.
http://www.nokia.com/about-nokia/contacts/customer-service
Aug 26, 2010 • Cell Phones
2helpful
2answers
Inspiron 8600 does not charge batteries. Power
hello
As you have mentioned that power supply is working fine then there can be only two things.
  1. Your charging module in the mother board is malfunctioning.And you cannot replace a particular module, you have to replace whole motherboard for it.If your system is under warranty Dell will do it for free.
  2. The connector which connects the battery with the mother board is gone.
hope this will solve your problem
Thank you.
Nokia 6070
Have you tried a new charger?
New battery?
Check the charging port where the charger plugs into the handset, there should be a small pin inside, if you cant see this then its probably broken off and you will need to replace the charging connector
Charging
seems like ur phone's charging point is broken or else ur charger isnt working .. try a different charger if it works den ur charger is at fault or else the point is broken
Nov 22, 2008 • Nokia 1100
2answers
Broken screen =(
Contact NOKIA Authorized sevice center nearest in ur area and they will remove the broken one and connect a brand new screen but first enquire abt the charges and stuff if ur mobile is not in warranty and even if it in warranty
Check whther u would be charged or not
Coz in many cases they dont charge u at all
But u might be charged as screen broke as it was not any problem that came with the phone ....
Dont go to any local engg to fix the problem, they might put a cheap or a fake screen which will work but they will not give u any waranty ...
VISIT http://www.nokia.com/
and check which is the nearest service center in ur locality
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
