Washing Machines Logo
Posted on Oct 01, 2009
Washing Machine doesn't spin.
KitchenAid SureCare Two Speed Quiet Scrub Top Load Washing Machine fulls with water and then doesn't spin. Model # YKAWE777BW
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 17, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1022
Points
Kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Spin cycle doesn't spin
what kind of washer is it top load or front load and brand.?
Kitchenaid quiet care washing machine
not enough information. there may be a loose or broken drum spring, or the belt may be loose and or worn. If its a two speed one of the gears may be worn.
Washeer model KHWS01PWHO it does not seem to be spinning or pumping out water and the code is reading FO2 but drain hose is clear
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
Set it toward the end of any cycle - it will sense the water level and pump it out before moving on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Top KitchenAid Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
