Dishwashers Logo
Eilidh McMurray Posted on Jan 23, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hobart Ecomax 502, getting very hot and switching off? Any help?
Attique-ur-Rehman
Level 3:
Top Expert:
  • Hobart Master 2,677 Answers
  • Posted on Apr 17, 2020
Attique-ur-Rehman
Hobart Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
879901
Points
8007
Https://www.youtube.com/watch?v=e2Bgh_UDpPM
https://www.caterkwik.co.uk/shop/downloads/HOBARTECOMAXH602_ecomax402502602-service-manual.pdf
2 Related Answers
Anonymous
  • 10865 Answers
  • Posted on Nov 04, 2009
SOURCE: Dear hobart representative, are there any
Hello. thanks for using fixya. Here is a link to the hobart service office nearest you. http://www.hobartservice.com/Locations/
ginko
Ginko
  • 19396 Answers
  • Posted on Sep 03, 2010
SOURCE: The Hobart Ecomax 500 comes
Hi.
If machine is in fault mode, and you get a fault with code 2 on display it means that the problem is when filling. Check if the tank is filling, check inlet and check the shut off valve.
ecomax by HOBART
Hobart Ecomax 652. How to reset to factory settings?
'reset'. It is a dishwasher, not a computer or cellphone. It has an electro-mechanical timer.
Service Manual for a similar model. ECOMAX 602/612/
https://www.google.com/search?q=Hobart+Ecomax+652+reset
Hobart Ecomax 652. There was a voltage jump after switching on, the water did not collect, there were no errors. I replaced the inlet valve, it did not help. then the message BOF. Help please
The BOF message on a Hobart Ecomax 652 dishwasher indicates a "boiler filling" issue, which means the dishwasher is unable to fill the boiler with water. Here are some things you can try:
  1. Check the water supply: Make sure that the water supply to the dishwasher is turned on and there is enough water pressure. If there is low water pressure, it may cause the BOF message.
  2. Check the water inlet valve: If the water inlet valve is not functioning properly, the dishwasher may not be able to fill the boiler with water. Make sure that the inlet valve is not clogged and is getting power.
  3. Check the level probe: The level probe detects the water level in the dishwasher. If it is not working properly, the dishwasher may not be able to fill the boiler with water. Check the probe to ensure it is clean and in good condition.
  4. Check the boiler: The BOF message may also indicate a problem with the boiler itself. Check the boiler to see if there is any damage or blockage.
If these steps do not solve the issue, it may be best to contact a professional technician to diagnose and fix the problem.
Dec 01, 2022 • Dishwashers
1helpful
Have a Hobart ecomax 452/502 dishwasher.. using too much auto liquid.... about 4 litres a day...
Remove the auto liquid , replace with water.
Start a washing cycle, wait two minutes till you hear the water filling inside. Open the door and pour a litre or so of Vinegar inside the machine. Let the rest of the cycle run.
This should clean out the inside of the machine if its not too bad. Otherwise you will have to find the "chemical sensor" and mechanically clean whatever is stopping it from sensing the water. It usually looks like two pencil ends about an inch apart.
If your machine looks "white" inside when its dry (from hard water) you might need a stronger cleaner than vinegar, or just try using two litres.
2answers
Ecomax 500-10
Hello. Have you find a wiring diagram for Ecomax 500-10 dishwasher ?
2answers
Ecomax 502 will not fill with water on start up
check the electrovalve, may have dirt stock on filter or the solenoid damage.
1helpful
Ecomax chf40 will not work temperature guage flashing 55 left 85 right then 5 left Et right how do i reset
Hi, error 5 on a Hobart Ecomax CHF40 relates to a faulty thermostat, it isn't a common or generic problem with this model, i have found them to be very reliable, its possible the probe has scaled up which may have caused the problem. i can be contscted through www.easicook.co.uk if you need any further assistance
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
