SOURCE: Our IntelliFax 3800 makes squeaky noises when faxing out
You'll need to replace the pickup roller.
SOURCE: scanner making grinding noise
Please open and apply oil on roller rod as some rust have accumulated on it prohibiting it move.
SOURCE: i have opened the above door and have cleaned the mirrors front
check the cables connected to scanner pcb monted left side of the machine. there is a flat cable connected to the pcb from scanner unit. layer of contacts may not be correct. check, clean and re-inatall the cable.
SOURCE: Scanner bulb stuck on left after mirror cleaning, machine frozen
The scanner is locked. You need to see the user manual and look for the scanner lock. It just needs to be switched to unlock.
SOURCE: Pentax ME Super: Mirror sticks in DOWN Position
The shutter & mirror is in need of a CLA. Clean, Lube & Ajustment. Its well needed for any camera when they are 20 years old and older
