Refrigerators Logo
J
Jean-Marie Deny Posted on Jan 18, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to get rid a a NORGE NNT1219K, but it cannot go through the kitchen door, even when dismounting the fridge's doors. What can I do?
Jorgie Navito
Level 3:
Master:
  • Refrigerators Master 357 Answers
  • Posted on Mar 12, 2020
Jorgie Navito
Level 3:
Master:
Answers
357
Questions
0
Helped
108931
Points
2245
Sounds like you will have to remove the kitchen door it self by taking out the hindges on the side with a screw driver and hammer just put a nail or screw driver in the hole and punch it up and out
Testimonial: "Thank you for taking the time to answer. Unfortunately even with the fridge's door AND the kitchen door removed, the fridge is way too large (about 1 inch). It came in through the window about 25 years ago but it cost a bunch to take it out the same route. I finally resolved myself to cut about 4 inches off the fridge's front. Actually not too difficult to do. The only thing you need to take care of is not cut the small pipe that goes around the front. After cutting and removing the outside metal shell, you need to dig inside the polystyrene, uncover the pipe and fold it back inside the fridge before completing the cut of the inner plastic layer."
  • Jorgie Navito
    Jorgie Navito Mar 17, 2020
    If ur going thru that much effort . it may be simpler to remove the actual door frame itself giving you bout 2 more inches , then nail them back in after. you can pry them loose with a pry bar
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Oct 15, 2008
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
Anonymous
  • 1122 Answers
SOURCE: kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Anonymous
  • Posted on Feb 06, 2009
SOURCE: hotpoint fridge freezer / howdens kitchen - no instructions!!
Luckily the hotpoint helpdesk admitted that the instructions for hanging the kitchen doors does not come as part of the standard instructions. There should be a seperate piece of paper with these instructions.
After some to'ing and fro'ing they managed to email me the required diagram.
Controlfrk
Controlfrk
  • 304 Answers
  • Posted on Sep 03, 2009
SOURCE: Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Dec 10, 2012
SOURCE: fridge still beeping even after the doors are closed
Is there a beep sequence?
Base of Door on Kitchen aid Side by Side. we replaced cam but door still falls off from top when we open. Can see this door sits lower the freezer side
Well Tell that Door to stop that! Imagine the nerve!
Oh what you need is the whole door replaced and the guides/cam replaced too! A little secret, somewhere you have lost or it did not come with it installed a part to that door. Call Kitchen Aid. They will Most certainly help you. Get your product I.D. number before.
1 (800) 422-1230
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Freezing refrigerator
Seal around the door should be "warm" not "hot" in my opinion... Only purpose for the electric heat in door seal is to evaporate moisture that will condense on the otherwise cold surface of the door seal causing drippage or if door seal on freezer to prevent frost buildup. In design of unit no reason that engineers would want or need to have this seal 'hot" because a mild temperature say 50 F would be adequate to do the job. Perhaps some physical damage to the electric wire in this circuit causing a short and more current to flow making it heat up???
Maybe not a baffle problem at all...... To me the baffle is such a simple device it would be hard to imagine how it would get screwed up. The one on my old Norge is almost 50 years old.... [ Yeah, I know, I waste probably twice the KWH that you guys do.... but my wife insists on keeping this old coppertone fridge and I keep rep[airing it over the years.]
What happens to filter if fridge is off for a month? It is a kitchen aid french door with freezer bottom. will the filter go bad and need to be replaced?
As water sits at room temps its can cause your filter to go bad or even clog. I would replace the filter and flush the system after filter installed to clean out the supply line to the dispenser door.
Safety first, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
2helpful
1helpful
Dismount door panel VW Golf
To remove the external door handle is not nessecery to dismount the door panel. Just follow my instruction: Open the door. Above the latch you will find small round plastic cover 1 inch of diameter.Remove it.There is screw T35 or T40 head/judish star/.Unscrew.Than slide the handle to the right about 1cm.Carefully pul out left side.That is it.
Reversed a door
you should be able to reverse your doors just take bolts out on hinges pop out plugs on oppasite side
2helpful
3answers
Www.ge.net How to get rid of flashing lock door on JGBP35
There is a button on the left upper corner by the door when you open oven. Hold the button down and press the clear button on the panel till the display clears itself. Just like that you have a functional oven.
1helpful
Hotpoint fridge freezer / howdens kitchen - no instructions!!
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
